Copy and Paste of CenarioVR Project into another CenarioVR Project
March 2, 2021 12:00 AM
I had a request from my stakeholder that could also be called project creep. They would like for an existing created CenarioVR Tour to also be added to another tour I am in the midst of creating. Is there a way to do this without copying/pasting each scene from one to the other? Please tell me there is :blush:
TIA,
TLCwithVal
Its a copy paste of each scene, or create a copy of the entire scenario and start your new project with that. At the moment Clips and "copies" are at most a single scene.
@johnb such a bummer ?, I totally would have copied the project and then started from that if I would have know it was needed, the problem with project scope creep... Ok then, will get my Ctrl+C and Ctrl+V warmed up ?
@tlcwithval You now have the ability to multiselect scenes to either copy/paste or create clips from much larger sections of your scenarios, so you should be all set with this now!
