click to activate... & lectora 2004 (sp3)
hi all,I'm using lectora 2004 sp3 with ie6. i get the message "click on this control to activate..." whenever i have a flash swf in the page. horrible.I've tried the solution mentioned in the link below and didn't worked. the "iefiexes.js" http://community.trivantis.com/forum_posts.asp?TID=2258&PN=0 &TPN=2my try:http://www.alumni.org.br/tmp/rodrigo/lectora/index.htmlit just don't work, also I tried this http://activecontent.blogspot.com/ that WORKED perfectly when i have a normal html (not generated by lectora), on the other hand if i use ths solution on the html generated by lectora it just doesn't work.Moreoveor, I can't update to other lectora version by now, i need to fix the problem with the version i have (v.2004 SP3(1888)desperately needing help.thanks in advice.
