hi, thanks for the immediate answer.i got it working in 3 ways, first just like you said, thank you.
Code:
You need to update your flash player to view this content
the above script goes in the head part then
Code:
replaces the entire object tag in the html.and second, when publishing the Flash file, in the HTML tab you can choose a new template 'active content update - HTTP' that you can download here: (http://www.adobe.com/cfusion/knowledgebase/index.cfm?id=7c2 9e252)it will put some extra code in your html to take care of the 'click to...' after publishing you can choose Commands -> Apply Active Content update that will ask for your published html file and put in the same directory a file called 'AC_RunActiveContent.js'. then just copy this js file to your lectora html folder and insert this html page as a external html and point tho the html (you have to save it as txt first).another way better than the 2 previous one can be found here:http://www.lucasferreira.com/flashtag/the awsome about this method is that you can put a JS command there and it will replace ALL your tags without you have substitute each object tag for a JS function.thanks for the help.rodrigo.
