The same issues exist when using the JAWS screenreader. We are aware of the problem and are looking into it. Unfortunately, there is no way currently to make these kind of objects respond to the Enter key on the keyboard. You can try Shift+Enter... this might work, and if it's a satisfactory solution, just ensure your users are aware of the key combination. If not, you'll have to stick with hyperlinks for now.
