This is FYI. I am using Lectora 2008 Enterprise Edition and recently discovered two characters that cannot be used in multiple choice questions with multiple correct answers. If you use these characters under these circumstances, then funny things happen when you publish.1. Do not use an apostrophe in the multiple choice question stem, with multiple correct answers. When I did have an apostrophe, and published to HTML and SCORM, the question only half published.(The text was published in reverse order, and none of the parent objects were displayed.) As soon as I took the apostrophe out of the question stem, the question published fine.2. Do not use a semi-colon (;) in a Quiz multiple choice question choice when you are also using the Results (and showing the questions and answers in the results.) The semi-colon that I was using messed up the reported Results. The problem went away when I took the semi-colon out of the question.I have reported both to Trivantis support.
