Chapter Level Audio
This is promising. I have not used Lectora frames before but per your suggestion I changed the title to frames style - header. That broke my course into two sections; header and main. Then I put an audio file in the Header. It does play throughout after being published to html. But when I place a change contents action on the first page of each chapter, the target options do not include anything in the header.This is promising. I have not used Lectora frames before but per your suggestion I changed the title to frames style - header. That broke my course into two sections; header and main. Then I put an audio file in the Header. It does play throughout after being published to html. But when I place a change contents action on the first page of each chapter, the target options do not include anything in the header.
