I have been using an .asp script to post test results from Lectora courses to my SQL server. This script had worked fine until the recent upgrade to 2007. The same course that successfully submitted results and had been published with 2006, when published with 2007 fails when trying to submit results.Does anyone know what changes in the new version could cause this? Has anyone who has used the .asp script in the past encountered this problem?Any help would be much appreciated!
