centering content and problems...
Did you try changing the Page Alignment for HTML Publishing in the General Tab of the Title Properties?This should make the adjustments you want in Horizontal centering. Not sure if you have any options for Vertical Centering, other than executing the course in a popup window (which is common when running from an LMS), or using an iFrame (which isn't compatible with older browsers). Our org only worries about IE for internal stuff, but try to stay standards compliant with MOST of the stuff we do just in case .SteveEdited By: sflowers on 38566.815
