CenarioVR not working with Lectora
August 25, 2021 12:00 AM
I built a simple project in CenarioVR. The biggest thing it does is allow movement from scene to scene so it is very simple. I published it as HTML5 to import into Lectora. I grabbed it through the CenarioVR option within Lectora and it pulls in there with no issue. When I view it in Lectora it will not allow me to go past the first screen. I published it on my ftp platform to test it and it does the same thing. When I click a hot spot to connect to the next scene it makes all of the items on my screen disappear, leaves me with an empty 360 room, and does not go anywhere. I pulled in a sample that I found in the discussions and it works fine within Lectora. What could possibly cause my project to not work when I import it?
Discussion (4)
Based on something that happened to me a few weeks ago (which was similar), try exporting your CVR scenario, then importing it again as a new scenario. This seems to fix certain types of corruption.
Thank you @carlfink - I tried it and it didn't work. It's still doing the same thing. I greatly appreciate your response though. Let me know if you have any other ideas. Thanks!
Hmmm... Not sure on that one but would love to help. Could you send that exported scenario to cenariovr@elearningbrothers.com and we'll take a look at it and we'll get to the bottom of it.
Can you navigate to other scenes in the scenario? That is, is the problem specifically going to this one scene, or does it happen whenever you navigate?
