Captivate + Lectora = help please
Do you have Flash? If so, open the captivate file in flash and add script to pass a variable to Lectora. If you search for passing variables from Flash to Lectora, you should find plenty on the topic. Do you have Flash? If so, open the captivate file in flash and add script to pass a variable to Lectora. If you search for passing variables from Flash to Lectora, you should find plenty on the topic.
