Hi,Can you tell me if AICC bookmarking is accomplished via the use of cookies? We are implementing an LMS system which is available to the users from home. So, if they begin a course from one PC and then try to finish it up on another I am trying to figure out if the data from the first attempt will be lost due to the cookie not being on the machine from which they attempt to finish up the course. If this is not the way that it is done, please explain how bookmarking is done.We are using Lectora 2005 SP4a and we publish to LMS.Thanks for your time.
