Bookmarking does not work when test questions are randomized
The reason the bookmarking does not work when you use a randomized test is that test is randomized in a new order for every session. Therefore, if the user answered the first question that was presented to them, exited out, came back into the course, picked up on the same question they answered the last time and since a new order of questions would be made, if that question were to be the last question in the new session order, the user would fail the test because they only answered one question. If you want users to be able to exit in the middle of a test and pick back up where they left off, you need to not use a randomized test. Again, just understand that when using a randomized test, every time they exit and come back in, a new order of questions will be asked.
lectoradev said:I need bookmarking to work with the course so users will resume back to where they left off in the middle of the test questions. When Ithe test questions are in normal order, bookmarking works. However, when I set the test to randomize the questions, the bookmarking does not work any more. If I exit out the course from LMS and launch the course again it starts from the first page. I need the bookmarking to work. I searched the forum with no luck. Please help and provide some advice.
