Best practices for converting Lectora courses to Dreamweaver?
This is because everything is rendered using javascript on runtime with Lectora pages. You can edit the javascript, but if you want to truely move from Lectora to dreamweaver, export the content from Lectora into XML. Then take that XML and reformat the content. You could write a program that looks at the XML and then reformats the pages to HTML. Its not easy, but it works.
