That shouldn't matter. Newer versions of XML should only create attributes that are not recognized in the older version. Unless the client has something really really old and the structure of XML changed so dramatically ...Without a sample of XML that has problems importing (which you can't send due to confidentiality ... there's nothing I can do to help. Have you tried doing it a piece at a time to narrow down where the import error is?Tim
