@dgimness
September 21, 2013 12:00 AM
I have autosave enabled in Lectora publisher, though it didn't autosave my file. Where is Lectora supposed to auto-save it to?
Do you have the Use Recovery File For Auto Save selected?
If you select it Lectora creates a new .awt file at each autosave interval (name preceded with a ~)
If you dont have it selected then Lectora just overwrite the .awt file at the specified interval
Global audio volume control??
