If you have flash player 8 you need to view the published version of the program over the web it cannot be on your machine unless you have changed the security settings other that that the coding does work I tired it and it does work.If you have flash player 8 you need to view the published version of the program over the web it cannot be on your machine unless you have changed the security settings other that that the coding does work I tired it and it does work.
