Audio Recording Tool
April 9, 2009 12:00 AM
You might also be picking up background noise (Air conditioners, etc..). You might want to construct a little box (think shoe box here) with one side open, and provide some padding/foam on all sides. If you're short on materials an old shirt could even do the trick. Put your microphone inside this box when you record and it will eliminate much of the background white noise.
