When I try to use the audio recording in Lectora Inspire 17 I get the following message, " The system cannot find the file specified." What am I missing?
It's likely the path to the audio recorder is incorrect in Preferences. Go to the Lectora Preferences and select Editors. Check the Audio path. You may need to browse to the editor if you recently reinstalled, depending on what folder it went to. You can use the folder icon on the right to browse to it. Mine points to a folder for Lectora 16, so you may have a new folder for Lectora 17.
