Login Sign Up
ELB Learning Logo
Topics
Members
Website
Knowledge Base
New Topic
Menu
  • Topics
  • Members
  • Website
  • Knowledge Base
  • New Topic
Archived
Report Abuse
Audio on/off
@kocagilli
September 18, 2006 12:00 AM
I found the answer. It was because I had compression selected for the Audio when publishing. Thanks!I found the answer. It was because I had compression selected for the Audio when publishing. Thanks!
kocagilli kocagilli
@kocagilli
View Profile
More From kocagilli
Navigation not working in scorm output
September 22, 2006 Reply 0 Upvotes
Attempts for tests
September 19, 2006 Reply 0 Upvotes
Attempts for tests
Attempts for tests
Join The Discussion
Sign Up Login
