Audio on popup?
I use Lectora 2007...the popup will need to have text on it with an audio narration. I was going to try to make a group that had text + audio, that is initially invisible. On a separate graphic, I'll add an action that tells it to show group on mouse enter...showing the text and audio (hopefully)...it can be on mouse click as well. I use Lectora 2007...the popup will need to have text on it with an audio narration. I was going to try to make a group that had text + audio, that is initially invisible. On a separate graphic, I'll add an action that tells it to show group on mouse enter...showing the text and audio (hopefully)...it can be on mouse click as well.
