Audio Not Working in LMS
In answer to this post is that one must either: 1. Turn the compression off for audio when publishingor2.When compression is turned on Lectora converts all video and audio to FLV. Chances are that if it works when viewing an HTML version locally and the audio is not working only on the server chances are that you do not have FLV as a mime type on your IIS server. Adding .flv MIME type in IIS1) Select the site to configure in IIS, right click and select "Properties"2) Under HTTP Headers Tab, select "File Types" under the MIME Map section and select "New Type"3) Type ".flv" as the associated extension and "video/x-flv" as the content type.4) Select "OK”
