Audio not working after publishing
What version of Lectora are you using? If version 8 or 9, try turning the compression for audio off when you publish the program. (Found on the Compression Tab during publishing) This could be your problem.What version of Lectora are you using? If version 8 or 9, try turning the compression for audio off when you publish the program. (Found on the Compression Tab during publishing) This could be your problem.
