Okay, if you are publshing to HTML, when you click Publish, there are several tabs that show up General, Companion CD, FTP Options, Proxies and Compression. Click on Compression and you will see the check boxes and a slide bar for audio, video and images. Unclick the box to turn the compression off and then click OK.Okay, if you are publshing to HTML, when you click Publish, there are several tabs that show up General, Companion CD, FTP Options, Proxies and Compression. Click on Compression and you will see the check boxes and a slide bar for audio, video and images. Unclick the box to turn the compression off and then click OK.
