Audio FLV files with cue points from Soundbooth
Ok the way cue points work, is that they are just timestamps in the file. You need something to actually interpret what to do at each cue point.
One way of doing this within Lectora, is to add all the cue points in soundbooth. Export the file from soundbooth(FLV). Import it as audio within Lectora. After you import it. Open up the properties window of the audio file. Click on the events tab. This should show all the cue points. Next you want to add actions to each cue point.
The other way of doing this is to create a flash file to interpret the cue points in the FLV file.
