I have found that the skin changes depending on the type of audio file. The controller for wma files is not as ugly as the mp3 controller. If you have the option to change your audio codec, you may want to test to see the different skins. It appears to use the standard for the codec.I have found that the skin changes depending on the type of audio file. The controller for wma files is not as ugly as the mp3 controller. If you have the option to change your audio codec, you may want to test to see the different skins. It appears to use the standard for the codec.
