Audio Controller Default Position on Slide
We are developing a number of courses using Lectora. On nearly every slide we have an audio controller in the upper right corner. Right now I am placing the audio file, then on the Position & Size tab typing in the X Coordinate and Y Coordinate so the controller will appear the same place on every slide. Is there a way to set a default position for inserting new audios for the controller? I would like to eliminate the steps clicking Position & Size, then manually typing in the coordinates.
