Audio controller
 If you convert the audio to FLV you will get a smaller nicer looking controller. The other option is to make your own buttons and with start stop playing actions on them. The button wizard is a good source for that kind of set up.
JM said:Hi, I'd like to replace the standard audio controller (slider) in Lectora with something smaller (and perhaps nicer looking). Is there a library of such items available somewhere from which to select one or more controllers and integrate them into Lectora? Thanks! J-M
