Audio buzz and system specs
July 27, 2006 12:00 AM
Eric, I have used a Sony digital recorder to dictate text. It has a USB connection and digital editing software. Files can be converted to Windows wave format. If you own Dragon NaturallySpeaking, the recording can be transcribed into text also. Perhaps this is a solution for you. Regards, Jon PaynePS, the above text was recorded and transcribed (I hate typing). If you send me your email I'll send you the WAV file. jon.payne@onity.com.
