Like Ben, I have not heard of this LMS before. The content Lectora produces is SCORM compliant so it should work as long as the LMS is compliant. One thing you could check is to see if you have any spaces in the AWT filename and the actual title name in Lectora, located at the top of the left hand pane. If so, try removing the spaces in the AWT file, open the file, remove any spaces in the title name and then republish the content out and see if that works for you. There is no issue with spaces in a file name according to SCORM compliance but I have seen where some LMS' have issues with them. Again, just a suggestion.
dav1d said:We just bought Lectora and we're really pleased with it. Unfortunately we're moving to a new LMS (Assimilate, developed by Ramesys) and when we try to import SCORM packages created in Lectora we get the error message "Unable to modify object data as the imported XML is invalid. " This happens with SCORM 2004 and SCORM 1.2 packages. Ramesys aren't providing any help with this. Has anyone seen this sort of behaviour before or could anyone hazard a guess at what might be the cause?
