Assimilate is a product developed by a company called Ramesys and as far as I know it's only used in the UK.
@Ben: I hadn't seen the test track before, it provides a lot of useful info so I'll definitely be using that more in the future -thanks for the pointer. In this instance the package works fine in another LMS and the test track didn't have any problems with it.
@Larry: I tried your suggestion but to no avail.
Thank-you both for your input, I'll keep plugging away at this.
Ramesys state that Assimilate implements SCORM 2004 r3 so I uploaded the LMS Test Content Package API from ADL and Firebug came up with this:-
Element referenced by ID/NAME in the global scope. Use W3C standard document.getElementById() instead. var result = LMSTestSCODriver.evalID( query1 + "!" + query2 );rn LMSTestSCODriver.evalID is not a function [Break on this error] var result = LMSTestSCODriver.evalID( query1 + "!" + query2 );rn
I found another test API at http://www.ostyn.com/standards/scorm/samples/proddingSCOwrap.htm and when I tried to import that, Assimilate gave me the same error as I had with my original package, saying the XML was invalid.
I'll report back any findings as they may prove useful to somenone in the future, in the meantime if anyone wanders by and thinks of something...
