asp cript problem
January 9, 2009 12:00 AM
In my experience, external files are not always handled by Firefox as they are by IE7. Perhaps you should install FF on your machine and give it a try. If your machine displays it properly, perhaps the user has javascript disabled? If it does not display, change your system requirements...In my experience, external files are not always handled by Firefox as they are by IE7. Perhaps you should install FF on your machine and give it a try. If your machine displays it properly, perhaps the user has javascript disabled? If it does not display, change your system requirements...
