Any way to lock entry fields?
If you are NOT using a test results page, I would make the answers to the MC question simply a, b, c, d. Then make those answer choice text boxes initially not visible. Then add a regular text box with the real answers that are lettered. Then align the MC radio buttons or check boxes with the answers in the text box. To the user looks the same.
If you ARE using the test results page then this will not work because the answer choices shown will be meaningless.
