Any way to lock entry fields?
November 6, 2009 12:00 AM
I've got some exercises where the user needs to input 3 numerical answers on a page.
Each input represents a separate question, and the user must process the answer of each question in sequence for feedback on the question. I need to 'lock' the input field so the answer can't be typed over once it's been submitted.
I tried putting using a show/hide action with a transparent text block over the entry field, however it hides anything that's been entered.
any bright ideas/experiences?
thanks
Roger B
