Any way to lock entry fields?
The devil is always in the details.
When I use preview mode to check the using a transparent box to lock an entry field, the box hides the underlying text. If I publish the course to html and check it, it works perfectly. So users - beware - preview mode doesn't always work perfectly.
Thanks to both Ben and Diane for posting replies. Both solutions work.
