Thanks for the suggestion, though I do not get a javacript error in IE. When the page displays the ~~~null~~~ error, the bottom left corner has the blue E and the word done. The error above (the one I said I found displayed in the javascript console of the firefox web developer extension) I have now found, displays whether the ~~~null~~~ error occurs or not. So I was wrong about that error causing the problem. What causes the problem is still a mystery and any other suggestions are very welcome.P.S. IE version that the error occurs on includes (but is not limited to) 6.0.2900.2180.xpsp_sp2_gdr.050301_1519.I have also tried Zipping the application moving to another registered version of lectora (same version of Lectora as above - different registration), publishing and uploading the html output. Same error occurs. I am running out of ideas now. Is there a support channel that goes directly to Lectora?? or is this forum it?Thank you.
