This is not going to be much help but check the bottom left corner of the IE screen in the status bar at the bottom of the screen. Normally there is a blue e there. If you see a yellow triangle with an exclamation mark in it, then you are getting JavaScript errors of some sort. Off the top of my head I would guess there is some problem accessing the JavaScript files.What version of IE?Edited By: bpitman on 2006-9-28 9:43:56
