After uploading course to Saba, 0 does not display in results response
May 23, 2012 12:00 AM
While taking an assessment, a response is created as a variable to be displayed at the end of the quiz in a text box using the change contents action. The quiz is not created with test items - it is created in a chapter using the radio group and radio buttons as form items.
When the course is previewed in Lectora Online it works fine and displays
You got 0 out of 4 correct
However after being published to Saba, it displays
You got out of 4 correct.
If they get 1, 2, 3 or 4 correct, that number does display as part of the response - only the 0 does not display in Saba.
Has anyone seen this before? Any suggestions?
thanks!
Jeanette
