Adding Power Point
No where near enough information to help you. 1. what version of Lectora are you using? Always include that. Different versions have different capabilities and problems. 2. Is the game now in Lectora or do you run PowerPoint by launching it from Lectora? What action do you use to start the game if it is still in PowerPoint?3. If it is in Lectora, how did you get it into Lectora? By hand? Did you use the PowerPoint integrator?3. In either case, what specifically does not work? ben
