Added some Media Library Images (Analog Clock) and am having problems
 Hi Dwayne -
It seems I’ve created the magical concoction that creates this problem. So, here are answers to your questions and a bit more information. Thanks in advance for trying to help me out!
1. Do the buttons work if you delete the clock from the page? (YES)
2. Do the buttons work if you put them in a different part of the screen, or add the next action attached to something else on the screen? (NO)
3. Do the buttons fail to work on currently working pages if you add the clock to them? (If I add it with the same set up.) Clock is set to auto play – the following actions are on the clock:
· Hide after 360 seconds
· On hide, go to next page (These actions work perfectly)
