I have Flash superimposed over a question in Lectora. In Flash, when the correct answer is chosen, the associated question variable is assigned to the correct answer; however automatic feedback does not happen because the radio button is still unchecked in the background. I've tried a multitude of things to activate the radio button, all to no avail. Is there a known javascript method to set the checked value of a radio button?
