Accessibility questions from a novice
1. If a user is using JAWS why do they also need a highlight?2. In Firefox if you hold down the Ctrl key and roll the wheel mouse you can resize the text. The text output from Lectora appears to usually be within tables and of a fixed font size so I don't think there's a way for a standard browser (IE6 ?) to resize the text.
