@c0rvette
October 29, 2013 12:00 AM
Does anyone know how to get a variable in a Lectora page to go straight to a related page in the Help Chapter?
Variables typically don't go anywhere. Did you mean a button or an action?
yes if I was on any page and I created a help button that the variable that was on that page take me to an exact link on my help chapter
Why are you using the variable in the first place? You only need a button with an action to go to the help page specified. If there needs to be some sort "only if" you do that in the action.
